zul
Aug 19, 2013Explorer
Thanks for the replys ... It does look like one of the clearence lights is the culprit for the beginnings of the rear panel delam. Is there a type of caulk that is suggested?
The rooftop seems pretty well caulked in most areas like around the vents and antennas. Cannot see under the AC unit, no way of telling what that looks like but clean from what I can see.
The roof top where it meets the front end cap has been caulked including the screw heads. If there was some delam happening to the front end cap and the previous owner cualked it tight, does that end the problem considering that the delam bubble is so minimal??
I'll attempt to put up a pic, not sure if I can ...
