dadmomh
Feb 20, 2014Explorer
We recently moved from our HTT to a Rockwood Ultra Lite 2604 and towing with an F-150 CC with factory tow and 5.4. The living area is at the rear and has the large rear window and plenty of windows around the sofa with air mattress, and dinette. Ours is a 2013 model, but I believe they made this model in earlier years. The downside I see to having a unit with the large rear window is that most of those - unless you get over the 30' - 32' size - would have only one bed and you'd be making up a sofa and/or dinette every evening.
It would help to know what you'll be towing with. Our 2604 has a dry weight of somewhere around 5500# or so - can't recall the exact number, but the GVWR is 6629#. Try to add that info to your next post with any specs re towing/weight and you should get more complete ideas. Good luck....we also love the large rear window. You might check into the 2604 and see how far back it goes and if that fits your budget, but you would have to make up the sofa bed nightly. Good luck.
