bobndot wrote:
Are you guys running the new heavy ply tires on the OEM rims ?
What are you doing about trying to match up the PSI ratings of the rims vs tires ? It seems like those 10 ply's are 80# psi ?
Are the rims rated at the same ?
how would you know what psi the wheel is rated for? I've never seen psi for wheels, just tires?
I found my Outback OEM aluminum wheels on etrailer and these are the specs they list:
Specs:
Rim dimensions: 15" diameter x 6" wide
Bolt pattern: 6 on 5-1/2"
Wheel bolt size: 1/2"-20
Pilot diameter: 4.25"
Offset: 0
Capacity: 2,830 lbs
Lifetime warranty against structural defects
https://www.etrailer.com/Tires-and-Wheels/HWT/TTWALS556655.html
