blt2ski
Jul 05, 2016Moderator
A WD in a nutshell, transfers weight off the rear axle back onto the front axle and trailer axles that came off due to the settling of the rear. IE if you put 750 lbs of hw on rear it might gain say 1000 lbs vs empty. Half of the additional 250 lbs might be off of the fa and ta's. A WD will put this extra 250 lbs back to the fa and ta. Reality is, if you try to put too much of the hw to the front or trailer axles, you may over load one or the other. the how much is removed off the fa will depend on many items, IE wheel base, rear suspension capacity, and even the weight on the fa due to a gas vs diesel setup along with how far behind the RA the hitch ball is, shorter overhang is better. 750 lbs on a dually might remove.all of 60 lbs off the fa. Your jeep on the other hand might be 250-500 lbs.
Personally, I.would not worry to much about a 3500-4000 lb dry trailer coming in at 5000 lbs loaded. Rigs Tuesdays are way better than years ago. You probably have more hp than the first bb v8 I drove, which was just under 200 hp.
Marty
Marty
