blt2ski
Jul 05, 2016Moderator
I've corrected some of the android phone auto-incorrections on the post above. My Walaby/Mike has better corrected what I was trying to get across re what a WD will do. You DO NOT want to remove ALL of the HW to the front axel or trailer so you have no HW. You can do this. You want to put back to the FA, what was taken off when loading the trailer on the ball mount. If your Jeep has 500 lbs removed from the front, you need to get this amount back to the front via a WD system. If you only remove say 50-60 lbs like 750 lbs might do on a dually, then a WD is probably not needed from a handling issue.
There is not a simple easy answer to this. Generally speaking, you are probably ok, UNLESS, you have a family of 6 as I do, with now 20 somethings, but 4 teens adult size in stature, that between the 6 of you, you are in the 1200-1300 lbs range, then do to the fact you have generally speaking, NO PAYLOAD for hitch weight, you have no trailer tow capacity. It does not sound like you have this issue.
marty
marty
