jawsthemeswimmi's avatar
Jul 04, 2016
Travel Trailer Tow questions
My wife and I have been thinking about trading in our 2012 Palomino Yearling 4100 popup camper for a travel trailer. We know what floorplan we want in a travel trailer and have been researching various models/manufacturers. Wants:
Around 4000lbs max
Heat
AC
Full bathroom (shower toilet sink)
2 burner stove minimum
Microwave or oven
Kitchen sink
Bunk beds (preferably double bunks)
Queen bed
U shaped dinette or standard dinette and couch on slideout (not required but it'd be nice)
Awning
Electric brakes
Some type of sway control
Any suggestions? I have it narrowed down to a few meeting all or most of these requirements:
KZ Spree Escape e250s
KZ Spree Escape 196s
Gulfstream Amerilite 248bh
Forest River Rockwood Mini Lite 2306
Gulf Breeze Ultra Lite 24RBH
Coachmen Clipper Ultralite 21bh
Primetime RV Tracer Air 205AIR
Forest River Wildwood X Lite 201BHXL
Forest River Flagstaff Microlite 23LB
Our biggest issue/concern is the tow vehicle is a 2014 Grand Cherokee 4x4 with a V6 engine. Max towing on the Grand Cherokee is 6200lbs. Is it unrealistic for me to expect this vehicle to be able to pull the type of trailer we want? If we stay around 4000lbs dry, I can't imagine we'd be over 5000lbs when loaded up. Is someone out there pulling a travel trailer or something similar with a similarly equipped vehicle. I'd love to hear some first hand experience? Suggestions?
Thanks in advance for everyone's input.
  • Don't pay attention to max tow capacity. Cargo capacity is what you should be concerned with. I have a 2014 Grand Cherokee (non 4WD)... Not that I tow with it.
    According to the stats I've seen, the MAX cargo capacity of any of the 4WD models is 1320 lbs. Some of the models are significantly less.
    So, your cargo capacity has to take into consideration all passenger weights, anything else you load in the jeep, the weight of your WD hitch (~100 lbs), and the tongue weight of your trailer. Tongue weight needs to be 13-15 percent of the trailer weight. So, a trailer loaded that weights 5000 lbs, the tongue weight would be between 650 and 750 lbs. Lets say 650. 1320-650 (tongue weight) = 670 lbs
    670 - 100 for WD hitch = 570
    That's how much you would have left for you, the wife, and I assume 2-4 kids (given you want double bunk beds). And again, that is the MAX cargo capacity of any of the jeep 4wd's.
    To get your cargo capacity look on passenger door for the yellow and black sticker. It will say something like max weight of all cargo, including occupants equals xxxx lbs.
    Mike
  • Your biggest weight problem is going to be the cargo capacity of your tow vehicle. The tongue weight of the trailer should be 10-15% of the loaded trailer weight. That tongue weight becomes part of your cargo. To that, you will need to add a good weight distributing hitch such as Equal-i-zer (about 60 lb), plus the weight of all passengers and their belongings loaded in the Cherokee.
    So find the cargo capacity of your vehicle and start doing the math.
    Tow rating is only part of the equation when it comes to selecting a proper vehicle/RV combo.
  • Welcome to the Forum,
    1st off, I would like to thank and congratulate you on doing your homework. You're doing good. 2nd, don't underestimate the Pentastar V6. It isn't a Hemi, but it will do the job at an easier pace. Does your JGC have the 8 Speed or 6 Speed transmission? The Car and Driver test shows it has the 8. I have the 8 in my EcoDiesel Ram, and it is awesome.
    I was towing with a Jeep Liberty with a 4 cylinder diesel. It got the job done, but it was a handful. Your JGC is a bit more vehicle than my Liberty, and staying small is a good choice, especially for novices. I had many years of towing beforehand when I got back into camping, so towing with the Jeep was OK for me.
    One thing I do suggest is a good Weight Distribution Hitch with Sway Control. I will suggest the Equal-i-zer 4 Point system. It is easy to setup for novices and does a great job.
