MitchF150 wrote:
old guy wrote:
all I can tell you is a 1/2 ton and a 3/4 is like night and day difference. I used to tow with a 1/2 ton and with the trucks passing you or the wind in general, power, and the truck being able to perform, a 3/4 will not let you down in satisfaction and safety. I would only buy a 1/2 again if all I wanted was to haul a sheet of plywood. I believe in my 3/4 ton that much
Really.... Man I thought I was out of touch with things...
Mitch
I actually agree with this. I wouldn't have a household without a 3/4 or 1 ton pickup truck. Buying a 1/2 ton truck knowing that you're going to be trailering is not well advised. 1/2 ton trucks are designed for people who mostly want a truck, but do not need a truck. While they have become more capable over time, they lack the features that come standard on 3/4 and 1 ton trucks for trailering.
Do 1/2 ton trucks work for trailering? For the right trailer, sure. But can you honestly say you would rather tow 8000 pounds with a max payload package 1/2 ton vs. a random 3/4 ton? The 3/4 ton comes with heavier springs, a full floating rear axle, lower gears, a heavier duty transmission, maybe overload springs, and E rated tires. And that's without specifying any additional options!
To me that's a no-brainer.
