willg wrote:
This is surly not the first post like this and probably not the last, but I am a newbie looking at purchasing a Rockwood mini lite 2304s dry wt. 5654, GVW 7660. I have never towed before. Finding the right tow vehicle is down right confusing so i”m looking for some advise from the experts! I don’t feel comfortable taking advice from car and rv sales people. Don’t want to overkill it, but also don’t to want to be underpowered driving in the mountains which will be a minimum of once a year up to the North Carolina mountains (Linville area). I’m assuming a 1/2 ton is sufficient. Looked mainly at the Ford F 150 2.7 and 3.5 EcoBoost engines so far. Thinking the 2.7 is too small. I would like any and all advice on any of the big 3 pickups but mainly advice on the appropriate pickup engine for the weight of the trailer. Thanks
If you drive a lot of unloaded miles, go for the Ecoboost, if you use it primarily for towing, don't bother, go with a 3/4 ton gasser. Towing mpg will be the same, unloaded mileage will be higher with the F150. If you want to save towing mpg, ecoboost will not achieve this, only diesel.
Gman
