I will testify to the fact my little ole 3.5L F150 w/ HDPP pulled my 6500# trailer all over the Rockies, from NM to CO, to ID, to WY, to MT, and to SD Black Hills with no problems what so ever. And I never felt unsafe nor on an unpleasant drive.
Some of the mountain passes, and steep grades and hair pin turns made me unpleasant at time, but that would have happened even if in a F250/F350.
marcsbigfoot20b27 wrote:
In my personal opinion if your trailer is at or over about 6000lbs and you only tow on the flats under 3000ft elevation then a properly equipped max tow 1/2 ton should be “ok”.
If you tow in the mountains and over 6K then a 250/2500 or 350/3500 would be the safer option and a more pleasurable drive.
