evanvalk wrote:
I would like some input from those who pull a travel trailer with a Ram 1500 Hemi 5.7 with the 355 Ratio rear end, Regarding speed, handling fish tailing any pro ot con, mostly Trailers over 30 ft. Thank you all. Ed
Here is the OP's question. I think every answer he got COULD be correct for HIS situation but as someone stated, he was just waiting for someone to say he was just fine. Maybe he can safely tow his TT, maybe he can't - you can argue about it till the cows come home. The answer can't be found by asking with such limited information.
Based on the info given Beemerphile gave the best answer.
What can be done is use information obtained here to figure it out for himself - if he's so inclined. But as he has the easy answer, I'm not counting on it. Good luck to you.
