evanvalk wrote:
I would like some input from those who pull a travel trailer with a Ram 1500 Hemi 5.7 with the 355 Ratio rear end, Regarding speed, handling fish tailing any pro ot con, mostly Trailers over 30 ft. Thank you all. Ed
Good luck. Ram has the lowest payload and weakest drivetrain of all the 1/2 tons. We're talking most are less than 1000 lbs payload. You will most likely hit the payload wall with that truck and trailer. Remember those dry tongue weights are just that - dry.
Suggest you upgrade to a Ford or GM with the max tow if you want to stay with 1/2 ton and that size of trailer. Or go to 3/4 ton but with modern 1/2 tons and good loading practices you should be fine.
