valhalla360
May 16, 2022Navigator
A 1/2 ton truck CAN be suitable but it depends wildly on how it's spec'd out.
There is the official tow rating but there is also the payload to consider.
You want around 12-15% on the hitch (more is better but often not practical).
So with a 7500lb GVWR, figure around 1000lb on the hitch which counts against the payload.
1/2ton truck payload: I've seen payloads as low as 950lb but also near 2500lb. At the upper end, you can probably pull at the full tow rating. At the lower end, a well fed American family of 4 can use up the entire payload before even hooking up the trailer.
SUVs are generally far less well suited to towing larger trailers. They are mostly designed for passenger transport and comfort take precedence over capability.
PS: Without actual scale weights fully loaded for travel, your use of GVWR is a good assumption. Use that with 15% hitch weight and you are probably good for selecting an appropriate truck. Be careful of sales men (and certain posters on this forum) who are happy to tell you to exceed the ratings. It's not fun when the rig handles like a pig.
44,072 PostsLatest Activity: Aug 23, 2026
