willald
May 24, 2022Explorer II
Grit dog wrote:valhalla360 wrote:
The strange behavior is making a recommendation that doesn't accommodate the OPs needs.
That's what I am saying too! See, we agree!....
I'm not sure you are, Grit dog.
You illustrated with your long, elaborate post that the SUV is overall a better vehicle than a van, when you look at everything. And, if you ignore the 10 people requirement the OP has, I don't think anybody would disagree with your points there.
However, as already said, no SUV can (safely) carry 10 people. Sooo, it really doesn't matter how many more 'points' the SUV has over the van, because it will not meet the OP's needs. The van will, albeit at a cost in many other areas you mentioned.
This has been a challenge for a very long time, and hasn't got any better over the years. How does one safely bring a large family (too large for a pickup) and tow an RV trailer?
Back when I was in that boat years ago, I had one of the few 3/4 ton SUVs (Ford Excursion) to do the job. Loved that truck, it was great. It worked great for what we needed at the time. Unfortunately, they are no longer being built. Neither are the other options that used to handle this well (3/4 ton Suburban, Ford E350 passenger vans). I guess now, the 1 ton GM van is the only realistic (new) option.
If I was in this position, needing to bring that many people and tow an RV trailer....I think I'd be looking for a used, older E350 Ford Van with a V10, and would just plan on spending the $$ to fix up whatever needed fixing up with it.
44,071 PostsLatest Activity: Aug 16, 2026
