- Retired_Enjoy_LExplorerWe were thinking of a Chevy Tahoe, GMC Yukon or Toyota Sequoia, rather than a truck. Thoughts on that for towing?
- agesilausExplorer III
bgum wrote:
Chevy 1500
Ford F150
You should get the trailering package.
You will be a little heavy for the lighter trucks such as Tacoma etc.
Ford
Ram
GMC
Trucks either 1/2 ton (F150/1500), 3/4 or 1 ton from the three American manufacturers. A HD truck lets you move up to a heavier TT later without buying a new truck. With tow packages for the 1/2 ton trucks. Avoid other brand pickups (like Toyota) which are not suited for towing. Try all three trucks brands out, you will like one more than the others probably.
Get a good towing hitch, a weight distributing hitch (WDH)
When towing keep your speed down to 55-62 mph, mostly stick to the right hand lane on highways and just let people pass you.
Your fuel mileage with be optimal in that range. Expect mpg in the 8 to 12 mpg range. And towing stability is much better and safer in that speed range. - Grit_dogNavigator IIIOP, tow vehicles to avoid?
Since you literally provide no other parameters for consideration to your very open ended question…avoid these….
Anything mid size.
Any smaller less capable full size suvs.
Any half tons that are base model drivetrains.
No go karts
Definitely no motorcycles
Compact cars and mid size cars are out of the question.
No minivans
That should aboot cover it!
Next caller please… - Grit_dogNavigator III
bgum wrote:
Chevy 1500
Ford F150
Lol, 5 pages in the TT forum with an owner scared of his own shadow and a buncha folks telling him how bad it will be with his capable half ton and the same weight trailer…..
Fwiw, any 7500lb trailer is absolutely half ton towable and I agree with you.
Just struck me funny is all! - LwiddisExplorer IITongue weight will need to be about 1000 pounds. Many half tons won’t be rated for that weight. My 1500’s max is 970 pounds. Avoid half tons.
- bgumExplorerChevy 1500
Ford F150
44,054 PostsLatest Activity: Dec 18, 2025
