Terryallan
Nov 17, 2018Explorer II
Bigdawgwill44 wrote:Terryallan wrote:
I would ask. What is the rear gear Ratio. Just because it has the max tow package doesn't mean it has the 3.73. If not. You will be pushing it with that trailer.
I have the 3.55 gears
You should be good. The 3.55 while not the best towing gear, is a good in between gear. Look in your manual. It will tell you the towing capacities for your truck. I'm guessing it will be around 8,500 lb. Setup the hitch carefully, get it right. You will know it is there, but then we all do.
Good luck, and have fun
44,066 PostsLatest Activity: Jul 25, 2018
