westend
Jul 21, 2016Explorer
You should inspect to see if you have a composite foam-core panel for a floor or sheathing attached to joists. The latter is easier to fix. The foam sandwich can be problematic.
Every travel trailer I've repaired had the floor installed underneath the exterior walls. When the floor decking needs to be removed, it is the world of a thousand staples and screws. A reciprocating saw and a grinder become your new friends.
