- We accidentally left a sliding window open once. After that our mini-blinds had a not so nice crinkled look to them.
- Dick_BExplorerWe travel with windows closed BUT ceiling vents open. In the summer it can get hotter inside the rig than the ambient temp so keeping the vents open helps to circulate the cooler air from outside.
- SoCalDesertRid1Explorer IILeaving the window wide open can result in the drapes getting blown off the wall, which has happened to me a few times. Leaving a window cracked a little doesn't hurt, but some windows have a tendency to open themselves alot more as you drive, if they're not shut and latched. That has happened to me too.
I don't worry about dust. I've always camped in dusty areas anyways. - beemerphile1ExplorerLeave them open if you like a layer of dirt on everything.
- GolfcartExplorerI leave my roof vents open in the summer time. I also have the air/weather deflectors
- dadmomhExplorerAgree, all you'll accomplish is getting dust and dirt inside.
- DrbolaskyExplorerAs a rule, we leave nothing open. You may not be able to see it, but whatever dust or dirt is floating in the air gets sucked in to your TT and covers everything in it. We will open windows/vents if we're parked for a meal or at an attraction.
- TvovExplorer IIWe close ours up tight. Lots of dust flying around on the roads.
- stevemorrisExplorerwe leave ours open a little unless its raining while on the road
we also leave the roof vents open but we have those cover/deflectors over them
I would not leave them wide open
44,056 PostsLatest Activity: Dec 27, 2025
