zul's avatar
zul
Trickle charger to replace Converter?
One day into a week long zion trip and all the low voltage stuff goes down... no lights and no water pump. The battery runs the low voltage 120v stuff but as the batt wore down we figure the converter is not charging. We checked the main fuses and all looks good ther. AC and micro were working from shore power but ... dead batt... fridge loosing cool... argh.
So the fix: $200-$300 on a new convrter? Um.. not now.
So ... can a 120v trickle charger do the job for $30-$40??
Please help if I am way out there w this idea but $$ seems to be a good cheap fix until I can afford the 3 stage converter!!?
  • A trickle charger isn't going to charge your batteries if you're using them. A trickle charge puts out .5 to 2 amps per hour depending on model - that's only good for keeping already charged batteries charged and handling the parasite loads like the gas detector. The convertor will put out a 30 - 60 amp charge.
    You either need to buy / borrow a good battery charge (10 amps min)or buy a new convertor.
    Bill
  • Within my previous TT, it had a 12 Volt - 140 Amp Converter. I replaced with simple out/in 145 Amp Progressive Dynamics model with NO wire changes. If wondering, its output in 45 Amps. re: - click here - A 12V trickle charger (on battery) is often 1 Amp (or less). Normal battery charger (on battery) is 10 Amps / 5 amps with slow rate 2 amps trickle charger.
    With above in mind, I might use a normal battery charger at 10/5 Amps and run all items on their 110/120 Volt settings "if stuck on a long weekend". But if not an emergency, I'd replace with properly sized Convertor. Do shop around (ebay and such) because selling prices of RV Convertors do dramatically vary.
    Hope this helps.
