joe0508
Mar 27, 2014Explorer
trickle charger
I have been having an issue when running my generator for long periods the batteries will eventually run down.I was curios if i hook a trickle charger up while running the generator if it will cure th...
KD4UPL wrote:It seems to be the starting battery that runs down because the generator starts and runs fine but the coach wont start after several hours.It seems to not be a problem when on shore power.
The problem is that something isn't working right. I'd fix that instead of add other equipment. If your RV is plugged into your gen. and while it's running your batteries are going down then your on board converter (charger) isn't working right.
If you're talking about a starting battery on a portable gen. going down while it's running then the charging circuit on the gen. isn't working right.
If this is on a MH and your saying the starting battery (and not the house battery) runs down then you need to find out why it's not charging. Some are wired to charge and some aren't. If your isn't then I'd install a circuit to charge it from your house batteries.
