Jonnygsx's avatar
Jonnygsx
Trim size on 98 prowler?
Trying to figure out what size exterior trim I need on a 98 prowler 24lz. I need to replace the rubber inserts that cover the screws. I pealed some off today and it was all brittle and cracked but I forgot to measure the size and the trailer is stored an hour away. Any one have a prowler they could measure the trim on?
  • Yes it is generac trim if you order the wider it will have a higher arch if in a narrow channel.th majority that i have replaced on trailers has been the narrower but without a piece to compare or measure hard to say.
  • newman fulltimer wrote:
    There are 2 sizes a half and one inch take a piece to the dealer parts they sell it by the roll or by the ft
    As I mentioned the trailer is an hour away and Id like to order this now so I can put it on next time I go up. It appeared to all be the same sized trim on my trailer, or were you saying there are 2 standard sizes used and not being specific to my prowler?
  • There are 2 sizes a half and one inch take a piece to the dealer parts they sell it by the roll or by the ft
