Mickeyfan0805
May 27, 2021Explorer
Thermoguy wrote:theoldwizard1 wrote:
Make sure the tanks are empty and don't overload the bed.
In my opinion, this is a bad recommendation. If you have to travel with limited or no fluids in your trailer, then you have the wrong trailer or wrong truck. You should be able to haul your trailer with the tanks all full. With very limited options to camp in a campsite with full services like dump and water, you often have to boondock if you want to go camping. If you boondock, you have to start with a full tank of water, that tank will be mostly empty on the way home but then the grey and black are full - or mostly full. We have had to fill 5 gallon jugs and add fresh water to get through a few day boondocking trip, for showers, etc. The trip home I have a very heavy trailer, full tanks, typically some water still in the fresh tank. When boondocking, your not going to have services near by. You might have to drive over a pass, large hill, or miles to the nearest services. Do you want to have your setup overloaded? Best to consider the real full weights then make a decision based on that. Plan ahead, not the opposite.
I'm all for planning ahead and being thoughtful about weights. That said, we are in our 12th season of camping as a family and have never one boondocked. What might seem 'necessary' to some is never on the radar for another. We all do this differently, and our plans and expectations should match our particular usage.
