bkenobi wrote:
Ok, so it sounds like I should get a shim of mat for the Shor term if I can. A permanent solution is what NL said (1" plywood and 3/8" rubber mat). I don't dare go less than 1" as this truck has a satellite find on the cab which will damage the cab over (or vice versa) when bouncing down the road.
We used to have a bigfoot which I believe uses the same mold to create the body. We had to shim it up to clear the cab with 1-1/8" plywood. We just sold it to a dealer that came to pick it up in a Ram and it didn't clear the top of the their cab. They drove it off anyway contacting the top of the cab.
But yes, we had issues with both the clearance at the tailgate posts and the top of the truck cab.
