bkenobi
Apr 16, 2017Explorer
Truck bed mat options
I have my 2007 NL 10-2QRR mated to a 2016 Ram 3500 SRW LB. The dealer recommended a bed mat to prevent slippage but they only had 4'x8'x1/4". I thought it was a little thin, so I decided on a 4'x8'x1" stall mat.
The problem is, I'm getting a little sag in the back right when on the truck so the side wall touches the vertical tailgate post (causes rubbing) and the diner box separates from the back wall by 1/2". When I drop it back down on the jacks, everything is fine.
Keith at NL said this is not a common problem and it could be how it's mounted. They recommend a 1" plywood and then 3/8" DeeZee mat on top. The dealership suggested trying to shim between the mat and the outer bed wall with 1" of something (plywood, mat, etc) to support the outer wall of the camper.
Does anyone have thoughts on this? I was going to cut down a couple plywood shims, but thought that could add a stress location at the back outside corner that might damage the fiberglass. Ideally I would think a mat that was the shape of the bed and 1" to 1-1/2" thick and contoured to the bed ridges would bethel way to go.
