bkenobi wrote:
There are 2 goals here. The stall mat is slippery and doesn't create a flat support (the edges sag to the bed ridges/valleys). Second, the stall mat is 3/4" thick and NL recommends 1-3/8" for my truck/TC combo. The last extra goal is to support the camper aft of the bed by having the plywood extend beyond by 6-8".
Either way, I was simply asking for a recomendation for sourcing the mat material I've seen others use in photos.
3/4 mat and 3/4 plywood gets you there and you can double up the plywood behind he stall mats if you want the full 8’ long of support.
I’ve not found bed mats to be any more grippy than horse mats. I think you’ll find the same. If it’s soft enough to not maintain line between the ribs of the truck bed it’s as soft as a bed mat.
If it’s the surface finish that is slippery because it’s new, idk, scuff it up maybe? Hook it flat and drag it down the road to scuff it up.
