jsc253's avatar
jsc253
Truck camper and tow bars
Hello all,
I am looking to tow a Jeep and would like your experience and thoughts regarding tow bars. I'm trying to decide on the best set up. It seems a tow vehicle mounted tow bar would be the most convenient for storage when the Jeep is detached but I'm not sure if it will interfere with getting in and out of the camper. The second option (and potentially cheaper) would be using a standard ball on the truck and a tow bar that connects to the Jeep. This may allow quick disconnects but I would want to remove the whole contraption before really using the Jeep. Storage of the tow bar at a campsite is something to consider.
My current camper has the door directly above the hitch (the camper does not hang over the bed. Another consideration is my next camper may be a Lance 825. That camper would extend beyond the bed and need a hitch extension but the camper door is offset to the driver's side, giving a little more room to store a truck mounted tow bar.
What have you found works best? Thank you in advance
  • jsc253 wrote:
    A picture is worth a thousand words, thanks! I also have the Stow-n-go steps, but unless we are going to be stationary for a while, usually take a folding step stool. How do you like the Maximus3/Falcon AT set-up?
    The setup works great. We tow on a lot of BLM/USFS roads as well, and managed to bind up the bars on a tight turn and one of the Maximus-3 loops ended up bending. I used a snatch block and the winch to bend it back and towed it several thousand miles since. I'm not sure what would have gave if that wasn't the weak spot, but do wish that these were made with 3/4" plate instead. I'd still go with the same setup, if buying all over.
