rockwind1
Nov 03, 2020Explorer II
Supercharged111 wrote:mkirsch wrote:rockwind1 wrote:
thanks,,, my gvwr is 6300 lb my front axle is 3000lb, my rear axle is 3450lb with my stock tires 265/70 r17
Are you SURE about that?
Those sound like F150 numbers, and a pretty light duty F150 at that.
Usually a 2000's era SRW F350 has a GVWR of around 10000lbs, a front axle rating of 5000lbs+ and a rear axle rating of at least 7000lbs.
This. My 1500 has ratings right at the numbers the OP is spouting off. My 97 GMC dually has a RAWR of 7500, but the axle itself is rated to something like 8700# last I checked. 3500# axle ratings get you NOWHERE, as in 500# of tongue weight and no camper whatsoever.
guys, my apologies,, that is actually my 4runner specs, i was going off a picture i took while ordering some stuff online for my 4runner, i thought it was the picture i took of my f350 tag. oops, i really thought those numbers were low as well. here is real info.
my gvwr is 9900 lb my front axle is 5200lb, my rear axle is 6830lb with my stock tires 265/70 r17
44,066 PostsLatest Activity: Apr 16, 2026
