towpro
Mar 12, 2016Explorer
Truck Camper battery isolator
since my Dodge charge wire is always HOT, I think I want to put in an isolator so I can not have to worry about remembering to unplug the truck from camper every night.
Look at the Blue Sea 7601 I hope I can isolate the battery charge wire from the 7 pin and run it through this device, maybe mount it right in the battery compartment.
It appears these do not have any voltage drop?
my Dodge has AGM batteries from factory, and alternator is supplying correct voltage for charging AGM's, so I prefer no voltage drop through an isolator device.
Is this what I should use?
