CrowsnestGuy
Jul 31, 2017Explorer
Truck Camper COG
I have a 1995 Security 10C Timberline truck camper and cannot seem to find a listing for the COG on this unit. The company is out of business I believe, so how can I find this information? Thanks
CrowsnestGuy wrote:I installed a Stable Lift on my 11.5 Bigfoot (4000 lb), and ran it for about ten years. I had to remove it when I got my 3500 DRW.
The reason I am asking is because I want to purchase a Stable Lift for the camper and when I install it, I would like the Stable Lift to be in the proper position. ...
idaho_camper wrote:
Don't mean to hijack the conversation, but...
My AF 811 has COG marked with an arrow on the driver's side indicating it's *horizontal* location. I've always been curious, though, where the COG is located vertically on the unit.
Reddog1 wrote:CrowsnestGuy wrote:I installed a Stable Lift on my 11.5 Bigfoot (4000 lb), and ran it for about ten years. I had to remove it when I got my 3500 DRW.
When I installed it, it went through the drama of locating the COG. I eventually discovered it was not critical. What worked for me was to load my TC. Place the single jack on the driverside of the TC. Center the jack on the axle. Eyeball is fine, this is just for aesthetics. I was unnecessarly overly concerned with the install of the Stable Lift. I installed it myself with no help, and called Stable Lift two times. The only thing critical is the saddle adjustment. I can provide you with more info on my install if you are interested.
Not a hijack at all actually. The vertical COG will vary with camper design and placement of heavier appliances and or storage of heavier items.
Why I have a pop up. The Cg is lower because the vertical weight is less and my appliance are all set down low.
That keeps the camper more stable on the road in heavy cross winds and off road in off camber situations.
A hardsie with high mount appliances will have a high vertical Cg and will be more impacted in the above situations...
SidecarFlip wrote:
Not to demean the Stable Lift system but, that would last all of 2 minutes on my rig where I usually camp. I've been tempted a couple times to completely remove the camper jacks. As it is, I'l always leaning out the window to make sure I don't snag anything.
Another reason I run the HJ system. Nothing sticking out or hanging down to catch a wayward log or rock.
