DutchmenSport wrote:
Well, ... "THIS" coming from a Chevy guy!
I'm actually glad to see this. At least someone is trying to make a difference. BS or honest truth, if it get the attention of the three big manufactures, then I say.... good job!
I like to see the video as well, but reading this
article wrote:
TCM: The truck in the test appears to be a 2017 Ford F350. Can you tell us more about the specifics of this truck?
Scott: The truck in the test video was a 2017 Ford F350 XLT, crew cab, dually with a 6.7L Power Stroke diesel engine, and four-wheel drive. We test with multiple rear axle ratios, but I don’t know the rear axle ratio for the test truck.
For the test, we added the Camper Package which includes higher spring rate in the front, a rear stabilizer bar, and a rear auxiliary spring.
shows that the author of the article and the technician are idiots who don't know what they are doing.
Test looks good on the picture, but how much value will you put to 2 idiots commenting?
Than the picture shows that ESP with camper on this truck can become danger. I would love to hear Ford engineers explanation if the system should be turned off for TC hauling.
Common knowledge tells to turn it off in slippery conditions.
I will not even split hair over the fact that solid cage, bolt-on simulator is far from real life camper who will rock on the bed in such maneuvers.
