Thunderbolt
Aug 01, 2016Explorer
That is correct info. It doesn't mean your transmission will fail. It means you need to change the fluid more often than normal to protect the transmission. Lugging it in high gear at low rpm's is harder on everything than letting it downshift and run higher rpm's.
Trnrbrnr wrote:
Yes, this truck does have the 3.42 rear end.
Regarding the acceptable temperature for transmission fluid, we checked internet references on the road and the guidance that we saw indicated that 180-200 F was a normal operating range and that temperatures above ~220 F would contribute to an accelerated breakdown of the fluid. If the temp gets to 250 F, shut it down. Some references show a temperature duration/rate of breakdown relationship.
For example, http://transmissionrepairguy.com/transmission-overheating/
