sharetheroadw_b's avatar
Oct 18, 2014
Truck for Eagle Cap 1165?
We recently traded an Arctic Fox 990 for a EC 1165. Besides missing my AF, I'm trying to figure out what bigger truck to put underneath this monster. I found a deal on a cab/chassis Dodge 5500 but it has 4.88 gears! Which it looks like most of the 450-5500 are all running pretty low gears. I want a payload rating of at least 6000# after the diesel and 4x4. Anybody have any experience w/ the bigger trucks, fuel milage and the like? Suggestions on a custom flatbed that won't raise the camper over 13'?
Thanks in advance!
  • There is not much of a price difference between the F450 and F550, but the 550 can carry up to 10,000 lbs. Once you have storage boxes on a flat bed, you can significantly add weight to your rig, so I would avoid the F450.
    Palfinger makes the Badger flatbed with low sills allowing the camper to sit lower than some of the other beds. You can get it with a goose neck trap door if you have a need.
    These chassis cabs typically have a range of axle ratios available from 4.10 to 4.88. The middle 4.30 or 4.44 is a nice compromise between highway cruising and trailer pulling capacity.
    The engines are derated with a lower tune than the pickups to allow longer duty cycles at maximum output. I'm not sure if this will help or hinder fuel economy, but it will increase engine life.
  • Just for a kinda-sorta similar comparison, I get about 10.5-11 with my EC1160 on an F350, running 4.10 gears. 10 or under with the trailer in my sig pic added on.
    I have considered in the past getting a Gear Vendor over drive. But the cost vs. Return On Investment in fuel savings didn't pencil out well.
  • I am running an 08 F550 with the 4:88 gears. My curb weight is about 15,000# and the 6.4L Ford PS only gets us about 8 mpg which I feel is too low. I will be looking at programming and other modifications in the spring to improve on this mileage. With all of that said, this truck pulls great. I tow an enclosed tandem axle trailer loaded with a work bench, tools, generator and an 87 Jeep rock Crawler and I towed this setup over Cottonwood Pass in Colorado last August. I am careful with my equipment so when we were on the extremely steep inclines I ran about 20 mph. No sense in stressing that trany while I was out in the middle of nowhere.
    The newer trucks have an upgraded transmission with more gears than I have. I believe my '08 is still running a 4 speed
  • Don't be too afraid of that gearing because the auto trans has a double over-drive.
