valhalla360
Jul 26, 2021Navigator
Can you move weight to the other side?
Assuming there is nothing wrong with the suspension, it implies you have more weight on one side...shifting some back will level it out.
If you adjust the springs, yes, it will leave that side high when unloaded. I suppose if you had airbags with integrated control, you could change it on the fly but better to even the load out if possible.
