DieselBurps
Jun 25, 2015Explorer
romore:
I checked the fuse box under the hood, and the 40 amp fuse labeled "trailer" which I am assuming goes to the 7-way pin and it was good. Had the battery "load tested" at autozone today and they said it was "bad"
DWeikhert:
Fridge is on propane at the the little gas symbol is lit up. I do have 12 volt fans that kick on when it's really hot.
I am going to check if there is power at the 7 way connector. Pretty sure this battery is bad, I went to costco today to see if I could get the 6 volt batteries they have, but they are 7 1/4 inch wide and the battery compartment on my Northstar is 13.5 inches so those arn't going to work. I might look into the "universal" brand agm batteries in 12 volt they appear to only be 6.5 inches wide.
DWeikhert:
44,056 PostsLatest Activity: Jan 12, 2020
