I am thinking of buying a 2000 F250 XLT Super Duty,7.3 PSTD, auto trans w exhaust brake,RWD, limited slip, tow pkg,rear overload springs, firestone rear spring air bags, 2006 Lance 915 lite, no genie,...
Presume it’s a long bed? Yes that truck will haul that camper quite well. Only other mod you might want to consider would be a rear sway bar if it doesn’t have it. Not a necessity but will help with body roll or sway. Again, not an issue to tow a little trailer behind it, presuming the truck is mechanically healthy. What I’ve found is most of the stress on the truck is from the TC, not a trailer. I get nearly the same mpg with just the camper as with camper and 6000lb boat/trailer in tow.
