georgehebert's avatar
georgehebert
Truck ratings
Other than the suspension components, what are the other differences in truck ratings from F150- F250- F350; Chevrolet uses 1500, 2500 3500 ratings. Chrysler uses similar badges.
  • Than for my anything with SRW is grocery getter, not a truck. ;)
  • I'm sure you will get plenty of input.
    I have an F-250 and am most familiar with Ford products so I'll take that bite of the pie.
    An F-150 is a light truck, with an entirely light duty suspension and a GVWR of around 9,000lbs in it's heavies configuration. Perfect for hauling a pop-up trailer or something in the 1500lb range of truck campers.
    An F-250 is a slightly lighter version of an F-350. It has the exact same axels and drive train as an F-350, unless ordered with "camper package" and/or a heavy duty suspension is has a slightly light spring pack with no overload springs or sway bars. It also could come with slightly lower weight rated tires and a max GVWR of 10,000lbs.
    When you pay the extra $350 dollars and buy a truck with an F-350 badge you get overloads springs, heavier rated tires and a max GVWR of 11,500lbs. Other than that it is the EXACT same truck as an F-250. Ordering a heavy duty suspension on an F-350 might net you a slightly stronger rear axel or a beefier front end if it is a 2WD truck.
    If you order a dually F-350 or F-450 you get a different truck, it has six tires and an even higher GVWR, a lower gear in the rear axel and is an even bigger, heavier duty truck.
    Every Ford diesel pick-up has the exact same engine and trans combo. That being said, transporting children in the back of a pick-up truck is not the greatest idea. Maybe you should consider a full sized passenger van?
  • I suspect the Front End components are more "beefy" as well?
    Are the trannys different or the same?
    My purpose: A Charter School in Northern Calif. is purchasing a suitable Van to transport young students 1000 miles per month. Snow conditions exists for Mount Shasta County.
  • jimh425 wrote:
    150s are a completely different truck.
    As in lighter frame, weaker springs, P vs LT tires, lower rated wheels, semi floating axle vs full floating. Well you get the picture.
    2500 vs 3500? Always a debate. Wheels, spring rates are usually the biggies. Oh and the rating per the door post tag. That rating is a certification number the mfg says the vehicle will be safe for occupants in an accident or emergency manuever.
  • I'm not sure what you are considering suspension, but 250 and 350 SRWs are very similar in most brands with the primary difference being springs, spacers, and tire capacity.
