srschang wrote:
BurbMan wrote:
srschang wrote:
So - I have a 2020 Ram 3500 that the dealer registered for 8900# when I bought it in March. I'm in NY state. No idea where they came up with that weight.
That's the unladen or curb weight, which means you have commercial plates. The reg form also asks for a "max weight", so that number should also be on the reg. It's really academic because if you're not for hire then you are not required to stop at weight stations, and the state guys won't be looking to pull you over for a safety check unless you look obviously unsafe on the road. The only "gotcha" is you need a CDL for anything over 26k lbs.
I would just leave it alone, why are you thinking you need to re-register the truck?
The current registration runs out end of February, and I need to reregister it for another two years. The only weight number on the reg is WT/Seats that says 008900.
The only reason I'm interested in increasing the weight on the reg is chatter recently on this board that California and BC are requiring non commercial trucks into the weigh stations. Will probably never go to California again, but will pass through BC on the way up and back to Alaska the latter half of this year.
ALL Weigh Stations in California have prominent signage that say NO PICKUPS
