JAL_Camper
Mar 18, 2021Explorer
Truck Shopping for Fiver
It's been awhile since I have been on the boards. Looking to move from the current lashup ('02 Suburban 2500 LT, 8.1l / '05 Jayco Eagle 29 BHS TT) to a Fiver and Truck.
Settled on a Jayco Eagle Fiver 336FBOK
Unloaded Vehicle Weight (lbs) 11,745
Dry Pin Weight (lbs) 2,215
GRVW (lbs) 13,750
Total Exterior Length 39' 8"
Exterior Travel Length (Pin box to bumper) 38' 9"
Going with a 3500 Diesel, Club Cab.
Questions:
1. Long Bed or Short (6'4")?
2. If short bed, sliding hitch -- Manual or automatic?
3. DRW or SRW?
3. Minimum Payload (The range has been 4,200 - 5,500 in my searching, only duallies so far)
4. Minimum Towing Capacity? (Range has been 23k - 30k, so I'm OK there so far)
5. Fuel Tank / In-Bed Aux Fuel. So far it's been 31 or 50 on the truck. Think I'll be OK with 50 and not have to add an In-Bed Aux Fuel.)
Regarding slider hitch - RV Dealer told me most ppl never use it. (I assume they are not backing up at sharp angles and/or have tapered front on their fiver?)
This will be the biggest (and likely last) RV as we are both now retired and plan to do extensive travelling and will be in the Rockies and other high elevations.
Thanks in advance to all your input!
GRVW (lbs) 13,750
Questions:
3. DRW or SRW?
