mountainsam's avatar
mountainsam
truck temps
Just put a set of gauges in my truck, 05 cummins automatic with Banks Engine Brake. We are headed out Monday for a 6 week cruise around the Midwest from California. GVW should be around 18k. What kind of temps are normal and what would be concerns?
First time pulling this trailer I pulled from Clearlake California to Redding and back last month and the transmission temp high was 154 and manifold temp high was about 870 at 24 pounds boost in the mountains. Flat land it never got over 140/670/4 with cruise set at 55 mph, California max for towing.
Thanks in advance for your feedback
Sam
  • thomasmnile wrote:
    Wouldn't say totally useless. My mechanic told me the stock transmission temp monitoring on my 05 doesn't activate the dash warning light until the fluid temp hits 280 degrees and that may be a tad late. When towing our fifth wheel the only time things got dicey was towing in the hills East of San Diego area heading to I-8. Saw 220 on the gauge and could SMELL it briefly, but the light never came on. Once off the steep grades all was fine and temp settled in around 180, ambient temps were high 90's.
    Actually, the threshold for the warning light is 260F, then it will lock out OD and lock the converter until the temp drops to 230F before it allows OD again.
  • On my '07 5.9L CTD towing 14K tall 5vr
    Tranny temp......output line 200*F pulling grades
    EGTs........pre-turbo rear cylinders 1250*F pulling grades
    Boost......28# pulling grades
    Cruising 62 mph
    Tranny 150*F
    EGTs' 850*F
    Boost 20#
  • Thanks folks for your feedback. Quess I will find out tomorrow what she does when I run up to Reno and beyond. When I bought the gauges ( TOWMAX) I installed the sending units as per dealers instructions and as the directions inside the packaging. I would think the inspection plug opening picks up oil and would have some value as a temp source. Not being a mechanic I didn't know for sure so that's why the question. Thanks again. Good Rv int to you all.
