mountainsam's avatar
mountainsam
truck temps
Just put a set of gauges in my truck, 05 cummins automatic with Banks Engine Brake. We are headed out Monday for a 6 week cruise around the Midwest from California. GVW should be around 18k. What kind of temps are normal and what would be concerns?
First time pulling this trailer I pulled from Clearlake California to Redding and back last month and the transmission temp high was 154 and manifold temp high was about 870 at 24 pounds boost in the mountains. Flat land it never got over 140/670/4 with cruise set at 55 mph, California max for towing.
Thanks in advance for your feedback
Sam
  • Yeah those temps are awfully low. Mine is hotter than that just driving it to town with no load.
    I'd like to know where the sensors are.
  • Sam, where is the trans temp taken, Outlet line to cooler? in the Pan? it makes a difference in the temp of course. On our last Dodge an 03(3500) with a mild upgrade the temps were IIRC a lot higher, trans going down the road 170's, EGTs climbing the Siskiyus I had to back off to get the EGTs below 1200, and boost would run somewhere around 22 pounds.
    So it sounds like your doing fine with those temps, although Clear Lake to Redding is not very mountainous IIRC?? Try Clear Lake to Salem Or for some hills LOL
    Good Luck and have fun on your trip:)
  • Boy those temps sound low to me. You should have no problems at all if you get that kind of temp. Even if it gets over a 100 you should still be very low on temps in the truck. That part of California are in the tipple digits for the next few days but I don't think the high temps will last. At any rate you should be good to go.
