Our travel trailer has a max weight of 7600#. So it seems only the 3 big trucks in the 2500/250 series will cut it. Or maybe something else? My question is, if we are wanting to only spend around $20...
7600 lbs can easily be handled by a modern 1/2 ton properly equipped pick up. A 3/4 will do it better if that is what you want. The real key is make sure you have a payload rating comparable to the tongue weight and cargo you plan to carry.
