sgip2000 wrote:
BillW44 wrote:
sgip2000 wrote:
How old is too old?
For the pickup not sure it matters too much, just concerned about the TT age in order to get into most parks without an age issue. I'm not sure how much the pickup age might matter regarding that. I don't know if there's some popular pickup even slightly older (around 1995-2000) that tends to last quite well (and common issues are well known and relatively easy to deal with).
A 9th generation Ford can be found in that price range. Pretty good workhorses.
As far as TT, I wouldn't get one more than 3-4 years old unless it has been meticulously maintained and stored under permanent cover.
Ok thanks for the Ford suggestion. Looks like they ran up until around 1997. Don't you have to start worrying about wheel bearings and that kind of thing by then, or do they hold up pretty well? Like to avoid that type of maintenance if possible although the price may balance it out.
I wonder if it would be considered too old even though the TT was newer, regarding certain parks age restrictions. Actually I was just looking at the 97 and it's looks pretty nice, so I see where you're coming from. I guess checking the weight pull ability would be due diligence.
Good advice on the TT. The elements beat this stuff to death when left unattended. Any particular couple of things you would watch for post 3-4 years old (besides the obvious water damage caused from not re-sealing windows/roof, etc.)? Like appliances? Or something else?
And I've repaired pretty much everything on my rigs (new ACs, water heaters, put in special propane lines, fridge, you name it) so should be good to go helping them at least fixing the basic kind of stuff. Just need to watch out for the major gotchas.
