DiskDoctr
Sep 27, 2017Explorer
l70cam wrote:
I believe you're right on the money lawrosa and I thank you for your input. Your math is exactly where I was at in thought and was questioning the scenario. I do think I will regret my towing scenario and if I were to purchase this camper and find out afterwards that my truck isn't compatible, I'll be in a sticky situation, especially with the wife, if you know what I mean. Lol!
Generally speaking, towing up to 80% of the published capacity is simple and with the proper setup will not be all that different than regular driving- just sluggish, wider corners, etc.
Going above that usually requires special caution and care. A very well-setup towing package and adjustment, slower, more driver skill, etc.
You are going to be over 90%. Unless you have modded the truck for this extra capacity, you will notice significant impacts on the handling, towing, maybe even trans and engine temps, etc. It also requires a great deal more skill and attention.
Each situation is a bit different, but if you're looking for a general guideline, 80% or below the published towing capacity is usually a safe bet. Above that is harder on everything, including you. It can be done, effectively, but know that you will want to be extra careful with it ;)
Good luck!
