2DHoop
Oct 03, 2017Explorer II
You will most likely NOT like the propsed set-up during those occasions when you will have to take an inlcine while passing or back-up with the wheels turned a good bit (uphill), or when the wind is sweeping accros the road.
Most of the time you will be on a level roadway thinking "this ain't too bad" but what you will remember the most from your trips are the times as described above, or worse, and this will make you tentative about doing it on a repeated basis.
Avoid RV PTSD and take into consideration the possiblity of a smaller trailer that still fits your needs.
