drc5900
Mar 31, 2014Explorer
My charge wire via the trailer connector gave way too much voltage drop.
Installed #2 gauge wire (as others above suggested), now voltage drop from truck batteries to camper batteries is practically zero, now the 2 camper batteries get properly charged when I drive.
I ran double wire between truck and camper batts, for both positive and negative, in order to eliminate any bad ground.
On the positive #2 gauge wire I installed breakers at both the truck batteries and the camper batteries.
Installed a solenoid so the camper batteries won't drain the truck batteries when the engine is not running.
Been running like this for 3 years, works great.
In future will install solar PV for when I stay somewhere longer time with no hookup.
44,027 PostsLatest Activity: Apr 19, 2019
