snarkee
Jun 25, 2015Explorer
Truck weight check
I have a 2015 silveRado 2500hd with a 2015 kz spree connect 322bhs
Cat scale weights
Truck only
steer 4040
Drive 3300
gross 7340
Trailer with without wdh
steer 3640
Drive 4680
Trailer 6920
grass 15240
Trailer with blue ox wdh at 10 links
steer 4000
drive 4180
trailer 7080
gross 15260
Trailer with blue ox wdh at 9 links
Steer 3880
drive 4320
trailer 7040
gross 15240
Gm says to return steer axle to 50% of empty weight. With 10 links I almost restored 100%. At 9 links I was just under 50%
I prefer the 10 link set up because the bars have more bend and it helps with sway control a bit more. Is it ok that I returned the steer axle to within 40 lbs of my truck steer axle with no trailer weight?
And did I calculate my tongue weight at 1380lbs and the trailer total weight at 8300 lbs?
Therefore my hitch weight is 16%????? Can't be
Thanks in advance
Cat scale weights
Truck only
steer 4040
Drive 3300
gross 7340
steer 3640
Drive 4680
Trailer 6920
grass 15240
steer 4000
drive 4180
trailer 7080
gross 15260
Steer 3880
drive 4320
trailer 7040
gross 15240
Thanks in advance
