ken56
Apr 14, 2022Explorer
afidel gives you good advice. If your heart is set on an Airstream then ...they are a heavy trailer. Check out the price difference between the 3/4 and 1 ton trucks. Diesel or gas, either way, your payload numbers are what are important. Tongue/pin weights of the trailers too. The dry weight numbers they give on trailers are pretty much useless because you are going to work with real world loaded and ready for camping numbers. Don't let any salesman tell you that you can pull ANYTHING with XXXX. The numbers tell the true story.
