dedmiston's avatar
dedmiston
Moderator
Mar 02, 2016
Trying to identify a 5er hitch
I bought a used 2014 RAM 3500 and it had one of these in the bed:
I can't tell what it is, so I don't know how to find instructions to get it out.
I'll be installing a B&W Companion and I'll need to get at those factory holes.
  • You could use that adaptor with a B&W Patriot 18k and save a few bucks and still have a clean bed... Unless you need more than 18k capacity.
    Thanks,
    Jeremiah
  • Thanks everyone. That did the trick. It took a little persuasion to get it out once I unlocked the handles, but it's out now.
  • BB_TX wrote:
    You can pull those pins and rotate the arms and lift that frame out leaving the bed and holes clear. That is an adapter frame for a standard bed rail mounted hitch.
    Yup. We have something similar for our Hensley TrailerSaver in the bed of our Ford. Rotate the pins and it lifts out.
  • You can pull those pins and rotate the arms and lift that frame out leaving the bed and holes clear. That is an adapter frame for a standard bed rail mounted hitch.
