GalWithDawgs's avatar
GalWithDawgs
Trying to understand payload
I have a travel trailer already but I want to buy a tow vehicle so before I go out and buy I want to understand thoroughly. I am starting with payload. I am looking at a 2007 Tundra 5.7L VV8 4 door 4 x 4 double cab. They claim the payload is 1,580. Am I to assume that from that 1,580 I must subtract the hitch weight of 720, my weight of 150, my dogs of 120, a full tank of gas, the receiver and ball, my ax, lipstick and anything else I might put in the truck? Am I right in this line of thinking? Am I missing something obvious that I should subtract?
Thank you for your help.
  • Ron (Lanerd) is 100% correct-o-mundo about weight distribution being different from sway control.
    Many, many, MANY folks mistakenly believe otherwise, and too many have come to grief as a result of that misunderstanding. The discussion at this link is a perfect example...woman writes in all puzzled about what caused their sway-induced disaster and describes what are clearly her W/D bars as "sway control". Except that they're not, as she and her husband found out.
    W/D setups do make a contribution to overall stability by way of restoring weight to the front end of the tug, but unless trailer sway control is incorporated into its design, W/D does not function for that purpose and must be added.
    Here's a written-for-us-novices article on sway control/WD hitches and how they're used together: Link
  • Slow down GalWithDawgs. As you shop trucks, check out the as equipped payload by locating this sticker on the driver's door or door jam. Note what each prospective truck has where mine says 2051:
    With 700 pounds dry TW, you will probably end up near 900 pounds loaded with camping gear, but some of that will be returned to the trailer's axles. 1500 pounds pounds of payload should be plenty. You may end up exceeding the GVWR/payload by a little, but the half tons do very well at or slightly over that rating.
    I do not understand the aversion to domestic trucks. Do you realize Ford/GM/Ram combined sell about 15x the amount of full sized trucks as the Tundra? How many heavy duty trucks are used by businesses to haul/tow every mile? Do you think that many people just keeping buying******over any over? There's your consumer's reports, real world sales.
