oldtanker's avatar
oldtanker
TT Air pressure
I upgraded my TT tires from some Chinese? brand 205/75/14 LRC to Goodyear Endurance 205/75/R14 LRD. Trailer states 32lbs tire pressure, new tires have cold pressure 65lbs. Di have to stay with what the trailer states or can I go higher? And if so how much?
Thanks, Bob
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" at the top?
    Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post your topic in the RV Forum which corresponds to the subject of your topic. Thank-you!
  • First off there's no ST tires in that size that uses 32 psi. The lowest is 50 psi.
    All trailer rims are rated the same per size and all ST trailer tires have the same load ratings per size. Doesn't matter what brand.
    14-5.5 rims are rated for 2200 lbs.
    205/75/14 LRD are rated at 2040 lbs at 65 psi.
    If you have newer style aluminum rims, that is you're not looking to put tires on a 20 year old TT then the above ratings would apply to you.
  • As long as the Rims can handle the pressure won't hurt to run at higher psi. This will not increase your load carrying capacity because of axle ratings. The Rims should be stamped on the inside with max psi rating.
  • The only question is can the rims handle 65psi, hopefully whoever mounted them would have noticed if they couldn't but I'd double check and then air them up to Max cold.
  • One of the reasons for up grading the load range from "C" to D"" like you did is so you can inflate to a higher pressure....thus gaining more payload and reserve capacity..
    Pump them up to the sidewall max pressure..They will run cooler and have less chance of failure..
