I have never serviced any vehicle brakes to just "clean them".. :)
Drum brakes do get some brake dust in them over the years, but will usually wear out before you need to just clean them.
For TT brakes specifically and if they are drum type brakes there will be an adjuster lever on them and in the newer ones, they will auto adjust.
I've had both and the only reason I pulled the drum off was to check the wheel bearings and then check the condition of the brakes and adjust accordingly.
With my new Rockwood, it's supposed to self adjusting brakes, but I plan on pulling the drums on them and looking for myself after a season and a half of towing it.
Just wanna check things out on it and see the bearings and how this so called auto adjusting thing works on it. Figure it's similar to auto drum brakes that auto adjust when you back up or use the brakes in general, in the case of a TT..
Anyway, going to pull them before the camping season and look for myself.
Good luck, Mitch
